F.P. Journe Octa Moonphase & Power Reserve
FORUMAMONTRES › Forums › FORUMAMONTRES › F.P. Journe Octa Moonphase & Power Reserve
  • #410000013752
    ZEN
    F.P. Journe Octa Moonphase & Power Reserve Octa1
    Un nouveau calibre et 2 modèles Octa
    F.P. Journe Octa Moonphase & Power Reserve Octa2
    CALIBRE 1300-3
    Citation :
    Automatic Octa watch with date and power-reserve indicator Bridge side – Under-dial view
    Indications: Central hours and minutes – Small seconds at 4:30 – Large date – Power-reserve indicator at 9 o’clock
    Dimensions: Total diameter: 30.8mm – Casing-up diameter 30.4mm – Total height: 5.86mm
    Movement features: 15-tooth, No. 8 escape-wheel. Free-sprung balance with four adjustment weights Flat Anachron balance- spring Mobile stud holder – Pinned stud – Spring laser – welded to the collet – Three-position crown – Slipping mainspring – Off-centre winding rotor
    Winding speed on rotator without mainspring slipping: 274 anti-clockwise rotations/24 hours
    Citation :
    Characteristics:
    Unidirectional automatic winding – Instantaneous date change – Date setting by the crown in position 2 – Time setting by the crown in position 3
    Balance: Frequency: 21,600v/h (3Hz) – Inertia: 11.0 mg/cm2 – Angle of lift: 52°
    Amplitude: 0h dial up: >280° – 24h dial up: >220°
    Time-keeping autonomy: 160 ± 12 hours
    Jewels: 27
    Finish: High grade – Circular stripes on the bridges – Baseplate circular-grained – Polished and bevelled screws – Pegs with rounded, polished ends
    Number of parts: Movement: 233 – Cased up on leather strap: 268
    Vu sur Tz
    #420000146760
    titof70
    Ok, certains vont dire que le cadran est plus encombré maintenant. Et c’est vrai.
    Mais, bien que personnellement, j’ai toujours trouvé que la définition précédente était très belle, je suis toujours resté sur ma faim : il lui manquait quelque chose.
    Là je suis sous le charme. Aurais-je trouvé mon graal (provisoire) ?
    La version avec la phase de lune est sublime.
    Quant aux mouvements, que dire si ce n’est que c’est toujours aussi fantastique, tout en or et superbement fini. bravohap bravohap
    #420000146761
    Incroyable ! Après des semaines d’horreurs, des nouveautés qui me plaisent ! Très belles ces Journe et les complications équilibrent le cadran.
    #420000146762
    ouai..bon c est sur c est pas laid..maintenant elle ne reprend pas les codes visuels des "vrais" Journe..alors c est sur c est pas laid..mais bon je me tape pas le cul par terre pour autant. What a Face Bon de dos c est sur c est vachemment sympa et ca change des anciens mouvement en laiton !
    #420000146763
    j’aime vraiment bcp, surtout la moon phase.
    et pour faire le lien avec un post sur l’utilité des fonds transparents celui-ci se justifie pleinement! quel magnifique mouvement!
    Antoine
    #420000146764
    Xaipe
    toujours de bon goût, j’ai plus de mal avec le 6 et le 7 renversés. La seconde décentrée c’est un must sous mon angle !
    #420000146765
    Oui mais c’est logique, les chiffres tournent toujours dans le bon sens ! C’est comme ma Cabaret le 6 est à l’envers (ou finalement à l’endroit) :
    F.P. Journe Octa Moonphase & Power Reserve Lange02nh4
    C’est ça la haute horlogerie : des chiffres qui tournent toujours dans le bon sens…
    #420000146766
    titof70
    Pas d’accord avec toi sur ce coup. Tu devrais dire que c’est différent de la première gamme Octa.
    Même si celles-ci s’appellent "Octa", cela correspond à la gamme "Souveraine", qui est la nouvelle ligne de Journe (cf Sonnerie Souveraine & co). Wink
    J’adore aussi la gamme Octa, mais c’est positivement inabordable.
    #420000146767
    la cave
    je ne suis pas un grand fan de cette superbe maison,mais il faut avouer que ces modeles me plaisent vraiment beaucoup salut
    #420000146768
    simplicity
    en fait, il aurait du la baptiser : chronomètre souverain à phase de lune ,
    le cadran étant AMHA , plus comparable à celui du CS qu’aux Octa , sauf si je me rappelle bien , que sur le CS , la réserve de marche est à 3 H ;
    en tout cas , c’est du JOURNE , et du très , très beau : boite et mouvement
    comme d’habitude . FPJ ne déçoit jamais ses fans : toujours de la belle ouvrage ! Impec
    Et en platine, j’aimerais bien l’avoir en main .
    #420000146769
    on a tous eu cette idee au début avec la souvrain ,c’est du Journe sans l’adn pour parler à la Hublot
    en fait non ,j’ai essayé la souverain en 40mm c’est une trés belle JOURNE avec tout ce qui va avec cette grande maison ,une vraie ,là encore il faut avoir la montre en main ,in vivo veritas comme dirait mon marchand de journaux Very Happy qui n’a pas fait de latin
    on remarque quand meme que le père journe il se ramène de plus en plus sur des complications "normales"
    il en a marre des sav sur les resonances surement Pleure 2
    #420000146770
    titof70
    Je suis assez d’accord.
    Le chrono souverain est vraiment une montre entrant dans la catégorie de celles qu’il faut avoir en main pour pouvoir en apprécier toutes les qualités.
    J’étais dubitatif jusqu’au moment où j’ai pris le temps d’aller la passer au poignet. J’ai eu beaucoup de mal à la retirer et à sortir de la boutique sans faire une très grosse bêtise.
    Exactement le même genre de sensations qu’avec la Richard Lange.
    Elle est d’ailleurs aussi très belle en or rose. Moins froide peut-être. Impec
    #420000146771
    nikolo
    bravohap bravohap
    Comme d’hab.
    Ah ce Journe… toujours aussi beau.
    Je sais pas si vous avez lu l’article sur http://www.horlogerie-suisse.com/ …
    Je ne vois pas exactement en quoi un remontage unidirectionnel remonte mieux qu’un bi…
    Sinon, c’est vrai que au moins c’est lisible.
    Parceque les vrai journe, faut tout de même de bons yeux pour lire l’heure.
    Je suis donc ravi de voir la souverain se compliquer un peu, car certes ce n’est pas la plus interressante du point du mouvement, mais on peut lire l’heure dans les lunettes….
    #420000146772
    Time to Time
    Est-ce que ce cadran ne manque pas un peu d’harmonie, avec ces indications dispersées un peu partout comme si on les avait aspergées au hasard ?
    Pour le coup, le Centigraphe (chrono au centième) que FPJ prépare pour le mois prochain paraîtra très ordonné et beaucoup plus classique avec ses trois compteurs…
    #420000146773
    "il en a marre des sav sur les resonances surement "
    J ai lu ca egalement. C est jolie mais parait il pas hyper fiable…Je ne sais pas si c est un defaut sur les 1eres qui a été résolu ou si c est plus structurel..
    Pour la matiere ca doit faire contrasté pas mal boite en Pt et mvmt en or ?
    Colonia
